BenQ MS612ST vs. Optoma GT750E - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-28-2012, 07:08 PM - Thread Starter
clanrakka's Avatar
So I've compared the specs of the two and didn't find any substantial differences but I'm a noob when it comes to projector technology.
The BenQ is on Amazon for $500 while the Optoma runs $759.
Is it name brand only driving the price difference or is the Optoma substantially better?
clanrakka is offline
post #2 of 5 Old 01-28-2012, 08:21 PM
b15nut's Avatar
The 612 is not HD. Compare the gt750 to 710st as both are 720p.
b15nut is offline
post #3 of 5 Old 02-01-2012, 10:31 AM
tenthbowl's Avatar
This is the most important difference between the 2. The Optoma's GT750E:
Decodes all HDMI 1.4a mandatory 3D format and SBS format commonly used by Blu-ray 3D players, game consoles and set-top boxes.
For example, if you have a PS3 you will be able to display 3D content without using an adapter.
The BenQ will require separate adapter to display 3D content from a PS2 or stand alone bluray player. The adapter can cost several hundred dollars, the Optoma 3D-XL costs $330 on Amazon or the Viewsonic VP3D1 $242.
tenthbowl is offline
post #4 of 5 Old 02-01-2012, 01:47 PM - Thread Starter
clanrakka's Avatar
Did you mean BenQ MX710? I couldn't find a 710ST..
post #5 of 5 Old 02-01-2012, 01:48 PM - Thread Starter
clanrakka's Avatar
3D is not an issue for me. I don't enjoy theater 3D technology so I doubt any affordable home version will be around for quite some time.
The 720p differential might be an issue.
