Projection at an angle - AVS Forum | Home Theater Discussions And Reviews
Old 02-07-2012, 11:21 AM - Thread Starter
sparrow171's Avatar
I am looking to replace my Panasonic PT900 finally and move it to a different room. The issue in the new room is that most projectors i've looked at are simply too deep for the shelf I have.
Is is possible to have the projector at a 90 degree angle to the screen and use a mirror at 45 degrees to reflect the image?
All input is much appreciated
Eagles may soar but weasels do not get sucked into jet engines
sparrow171 is offline
Old 02-07-2012, 12:13 PM
Riso's Avatar
Yes. I use a mirror with my setup. It works fine. If you are going to use the mirror at a 45* angle, you should get a first surface mirror. You could probably get one cheap or for free at a tv repair shop. They use them in rear projection tv's. You could have it cut to size at a glass shop. good luck.
Riso is offline
