Mitsubishi HC4000 or Benq W6000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-12-2012, 01:16 PM - Thread Starter
caperguy33's Avatar
Hello everyone, I am trying to decide between the Mitsubishi hc4000 or the Benq W6000. I can get the Mits for $1249.99 and free bulb. The Benq I can get for $1299.99. I read through both owners threads. Any advice is appreciated. Thanks as always and take care.
caperguy33 is offline
post #2 of 5 Old 02-12-2012, 01:32 PM
Joesyah's Avatar
What size is your screen?
Joesyah is offline
post #3 of 5 Old 02-12-2012, 01:40 PM - Thread Starter
caperguy33's Avatar
Thanks for your reply. My screen is 100 inch
post #4 of 5 Old 02-12-2012, 01:45 PM
Joesyah's Avatar
The Mits will be fine for that size screen. If you're not bothered by dynamic iris movement. The Benq is a terrific unit. It is much brighter than the Mits. The Mits will have better color out of the box and comes with a better warranty.
If you plan to use with ambient light from time to time. The Benq will do a better job, because it is so bright.
The Benq will do night scenes a touch better because of the DI. It should be a toss up overall. You'll probably be happy with either.
If you need more flexibility with placement, the Benq will fit your needs over the Mits.
Joesyah is offline
post #5 of 5 Old 02-12-2012, 02:11 PM
i too am looking at HC4000 or W6000
screen size 4me = 106in fixed white - Light controlled environment
BluRay & DVD movies only
present PJ = InFocus SP7210 (is there Noticeable PQ Upgrade)
from what i read::
the HC4000 is much less brighter than the W6000
and likewise dimmer than the SP7210 (but Spot on Color right out of Box)
i can make the Mits work-- Ceiling mount & Offset
what iam worried about is beginning FL=15 at my settings (and then it gets darker)
the W6000 is much Brighter (more in line of the SP7210)
NO problems with Offset (vertical Lens shift)
beginning FL = 33 (similar to SP7210) ie maybe 16FL at LAMP 1000hrs
BUT Color is NOT spot-on out of the Box (and maybe difficult to adj)
also possible problems with Iris noise & obvious adjustment flicker on screen
i too like CaperGuy33 would appreciate INPUT
Mouw is offline
