Epson 1760w vs Optoma HD65 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-20-2012, 02:16 PM - Thread Starter
wonkadaddy's Avatar
Hey all,
I'm trying to decide between these two projectors. The projector is going to be used mostly for an HTPC setup in my budget, plugged into some Klipsch 2.1's for sound. But I want to also be able to take the projector out for occasional presentations for work/school.
That's why I'm looking at these 2 models as they're both 720p, reasonably priced, and 3.7 and 4 lbs in weight respectively. The Epson is a little smaller and looks to have a tighter form factor in addition to weighing a little less. I'm not sure, but I get the feeling the HD65 has slightly better picture quality? The HD65 is also a good bit cheaper. Any feedback/advice on which to go with?
Or other models? I want at least 720p, and need hdmi and an audio jack, but everything else is up in the air. I see the Epson has a USB port which is cool, but it doesn't look like it works with pdfs or powerpoint files which seems pretty silly.
wonkadaddy is offline
