5 Great 3D Projectors - Which one is best? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-22-2012, 11:27 AM - Thread Starter
alkit's Avatar
Hi,
I currently have a Epson 8700 projector. I am projecting on a 119 inch High Contrast Cinema Vision Da-lite screen, in a living room (dark carpets, light ceiling, medium shade walls). I watch mainly movies with it.
Quality currently is great, but with the new 3D projectors just out, I was thinking of upgrading. Currently on my list and thoughts regarding each:
1) JVC DLA-X30 (Apparently the best quality on this list, however, 3D has flicker and crosstalk. Additionally, in my room, with the light ceiling, I don't know if I'd be able to benefit from the contrast advantage over the other projectors on this list. Most expensive option)
2) Epson 5010 (Great contrast in 2D, but no dynamic iris in 3D, so any 3D content will look bad compared to 2D)
3) Panasonic PT-AE7000 (Very good contrast in 2D, very good contrast in 3D. 2D will be a slight step down from the Epson, but 3D will be a step up. Additionally, bulb will not last as long as Epson, as it needs full lamp mode to run as bright as the Epson on Eco mode)
4) Benq W7000 (sharper image as this is DLP, however, the worst contrast projector in the lot).
5) Anything else in this class that I might have left out?
So, based on my choices above, has anyone had a lot of experience with these projectors and can recommend the best solution for me?
alkit is offline
post #2 of 7 Old 02-22-2012, 12:45 PM
BlackSS's Avatar
Optoma HD33/3300
I can not give direct comparison to the projectors you have listed, but I will give you my experience. The 2D is good, blacks are not great however.
3D is outstanding. In it's price range it probably has the best 3D out there with zero (to my eyes) ghosting, cross talk or flicker. The darker image really makes the blacks much better as well.
BlackSS is offline
post #3 of 7 Old 02-22-2012, 01:04 PM
theshadow1234's Avatar
What about the Epson 3010?
theshadow1234 is offline
post #4 of 7 Old 02-22-2012, 01:05 PM
adidino's Avatar
Quoted: 320 Post(s)
Liked: 254
Sony HW30 should be on that list but from your list the Panasonic.
adidino is online now
post #5 of 7 Old 02-23-2012, 11:26 AM
Pielicker's Avatar
Without question the JVC X30. Same price as the Panasonic. If your unsure, best to go into your local store and sample these out. I'm betting you'll go X30. I was sold on the Panasonic until seeing the X30 in action.
Pielicker is offline
post #6 of 7 Old 02-23-2012, 11:30 AM
ricwhite's Avatar
Quoted: 26 Post(s)
Originally Posted by alkit View Post
Hi,
No, the 5010 doesn't look "bad" in 3D. It's excellent. I actually have the 6010 and the 3D is great. Very good blacks. Little to no crosstalk. Colors vibrant. Motion is fine. I think the Epson 5010/6010 series offers a great balance of features and performance in both 2D and 3D.
ricwhite is offline
post #7 of 7 Old 02-23-2012, 09:15 PM
jnabq's Avatar
Liked: 39
I agree, loving my 6010 in 2D and 3D.
jnabq is offline
