Epson 3010 ceiling mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-04-2012, 04:52 PM - Thread Starter
counterbond's Avatar
any body ceiling mount there epson 3010 yet? im looking for a good ceiling mount to pick out
counterbond is offline
post #2 of 7 Old 04-03-2012, 09:23 AM
Suburban1's Avatar
Quoted: 16 Post(s)
Have you had any luck finding a mount yet? I just ordered a 3010 and have to start looking for a mount and glasses
Suburban1 is offline
post #3 of 7 Old 04-03-2012, 09:51 AM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
http://www.ebay.com/itm/CEILING-MOUN...item2a1662e19a
I got this one in December and have been happy with it. Shpped fast.
I've got the Epson glasses, the Panasonic 3rd gens and the PS3s. For the $$$ you can't beat the PS3s. JMHO
Hope this helps!
Ed
old corps is offline
post #4 of 7 Old 04-04-2012, 09:08 AM
vincentfox's Avatar
Chief RPAU
vincentfox is offline
post #5 of 7 Old 04-20-2012, 09:11 PM
thoomin's Avatar
I built a version of the Monkey Man mount, originally mounted off the wall, could easily come down from the ceiling. It's really not particularly hard.
thoomin is offline
post #6 of 7 Old 07-23-2012, 02:04 PM
Earthworm Jim's Avatar
I recently picked up my Epson 3010 as well and I bought the Atdec Telehook mount http://projector-mounts-review.toptenreviews.com/atdec-telehook-projector-mount-review.html
I've hooked it up to the projector and know it works well, it's a VERY solid unit and will allow for lots of fine tuning, check it out, I got mine for about $70 and it was totally worth it.
Earthworm Jim is offline
post #7 of 7 Old 07-23-2012, 03:24 PM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
I highly recommend the Peerless PRG mount. I recently bought one for my new JVC DLA-HD250 (~25lbs). It's a really solid mount that's very easy to install and very easy to adjust.
eljaycanuck is offline
