Getting A HD33. Need Advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-07-2012, 04:43 PM - Thread Starter
theshadow1234's Avatar
OK guys. I'm getting ready for the HD33 and i need some advice on my prep work to try and make this a smooth installation.
Here is the breakdown
It will be a ceiling mounted projector and centered to screen.
Mount is a Atdec TH-WH-PJ-FM.
Throw distance will be 12'.9" (where old projector use to be)
110" 1.4 gain screen. Top Of Screen Display to ceiling is about a foot long not including frame.
9 foot ceilings.
Light Controlled Room.
Since the HD33 has no lens shift do you guys think this will be an easy install or do i need to make some adjustments? Would i only need to mount the projector where the old one was with the ceiling mount and adjust the image on the screen?
What do you guys think?
theshadow1234 is offline
post #2 of 2 Old 03-07-2012, 08:18 PM
coderguy's Avatar
Quoted: 377 Post(s)
Liked: 306
Check my calculator in my signature, it will give you the precise offset and mounting spots if you enter your room dimensions in (ceiling height) and throw distance.
Access HERE from this thread
coderguy is offline
