AE100 service menu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-12-2002, 10:31 AM - Thread Starter
lenny100's Avatar
Hi all
I have just spend some time reading post about the AE100 and some of you have asked about the servicemenu.
I fell over this post by David James about some problems with the AE100 (altitude sickness) and he mailed Panasonic US
http://www.avsforum.com/avs-vb/showt...ighlight=ae100
The answer he received could indicate where the service menu on the AE100 might be
Look for the 3. post in the thread.
I dont yet have the AE100, so I cant check it out myself, but maybe some of you AE100 owners will?
/Lennart
lenny100 is offline
post #2 of 8 Old 05-12-2002, 10:37 AM
tahustvedt's Avatar
I wonder what happens if you choose the "SERVICE MODE" option.
Tor Arne
tahustvedt is offline
post #3 of 8 Old 05-12-2002, 10:39 AM - Thread Starter
lenny100's Avatar
Exactly my point!
lenny100 is offline
post #4 of 8 Old 05-12-2002, 12:00 PM
oddjob's Avatar
That "Service Mode" just cycles through the 3 primary colors with a few test patterns. There are no adjustments in there. Maybe there is a more comprehensive service menu hidden in there, but that is not it.
Keith.
oddjob is offline
post #5 of 8 Old 05-12-2002, 06:03 PM
thaxx's Avatar
All Panasonic's ......... To get further into the service menu, software from Panasonic is required, and it's not given out to Panasonic owners. I got this info from a Panasonic tech.
Mike
thaxx is offline
post #6 of 8 Old 05-12-2002, 06:33 PM
JPinTO's Avatar
The projector is controllable via the serial port and somebody posted the protocol for controlling it. While the panasonic document that discussed the protocol was limited to commands that control user functions that are available via the remote control, no doubt the service menu options are accessed in the same fashion. What we need is to get a couple of these things to some bored 15 year olds, and they'll hack it! :D
- JP in TOronto
JPinTO is offline
post #7 of 8 Old 05-12-2002, 06:38 PM
oddjob's Avatar
The AE100 does not have an externally accessible serial port, so the software isn't going to help at all. Perhaps there is an internal serial connection? Anyway, too many unknowns at the moment.
Keith.
oddjob is offline
post #8 of 8 Old 05-13-2002, 07:31 AM
NEO2000's Avatar
FYI, There is no internal Serial connection......
NEO2000 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
