signs of a dying bulb - AVS Forum | Home Theater Discussions And Reviews
Old 03-12-2012, 01:43 PM - Thread Starter
postmortemfear's Avatar
Just curious what are the signs of a dying projector bulb
postmortemfear is offline
Old 03-12-2012, 01:51 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Dim image
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 03-12-2012, 04:02 PM
jsgrise's Avatar
Quoted: 162 Post(s)
Liked: 57
brightness flickering
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is online now
Old 03-12-2012, 04:56 PM
Bohanna's Avatar
Liked: 24
A Dim or washed out Image. If you have a flickering lamp it could be the arc is jumping all over the lamps Center chamber. Take the lamp out and look at the center and see if it is distorted or out of round or the center stem has gotten offset due to heat. You could try setting it on economy if you have that setting and go back and forth between normal and econ.
Bohanna
Bohanna is offline
Old 03-12-2012, 08:26 PM
rovingtravler's Avatar
just remember a broken bulb in the projector can make for a big mess and some possibel damage. It is not worth the extra few hours.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
