Acer K520 LED/Laser Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-13-2012, 08:41 PM - Thread Starter
danceswithgeckos's Avatar
LED / Laser Hybrid Display Technology
2000 ANSI Lumens
1024 x 768 Native Resolution
4:3 Native Aspect Ratio
100000:1 Contrast Ratio
3D Ready
Anyone know the price range this will most likely be in?
danceswithgeckos is offline
post #2 of 5 Old 03-14-2012, 12:17 AM
eat meat's Avatar
to expensive,acer,viewsonic, and optoma.and whatever the benq blue core is(laser only)
now all we need is some one to mention a problem looking for a projector............speckle...................opps
its there you just cant see it................................ID
__________________________________________
Are you classified as human? Negative, I am a meat Popsicle.
(fifth element)
eat meat is offline
post #3 of 5 Old 03-14-2012, 12:23 PM
Mayuyu's Avatar
Contrast measured when the LED/Laser totally turn off? if no, then there's a very high number.
Edit: i found my answer.
DynamicBlack - adjusting the lamp output based on the overall brightness of the scene, darker scenes could use a lower lamp output which result in an better black level
Mayuyu is offline
post #4 of 5 Old 07-07-2012, 01:11 PM
3dprojector's Avatar
Quoted: 201 Post(s)
Liked: 101
now it's available on amazon.de
3dprojector is offline
post #5 of 5 Old 10-17-2012, 03:37 AM
uuddlrlrbass's Avatar
Is there a price yet, I looked through the press releases but didn't see one.
Will the k330 and k11 drop in price?
uuddlrlrbass is offline
