How Do You Guys Clean Your Lens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-12-2002, 08:27 PM - Thread Starter
Lebowski's Avatar
I was wondering what all you guys use to clean the lens on your projectors.
In case you don't know I have am AE100, if that matters.
Lebowski is offline
post #2 of 9 Old 05-12-2002, 08:30 PM
mikef's Avatar
I use lens paper and non-reflective lens cleaner- the same stuff I use on my 35mm and digital camera. Check your local photography shop.
mikef is offline
post #3 of 9 Old 05-13-2002, 09:14 AM
tony.tam's Avatar
Is it important to let the lens cool down? I think I've seen some lens cleaner solution mention not to use on hot lens.
tony.tam is offline
post #4 of 9 Old 05-13-2002, 12:00 PM
mikef's Avatar
I tend to clean the lens before I power it on, not when I am ready to power it off.
mikef is offline
post #5 of 9 Old 05-13-2002, 12:19 PM
Ricky D's Avatar
I never cleaned it up in the past 6 months !!!
I should think about it... it may not harm ;)
Ricky D
Ricky D is offline
post #6 of 9 Old 05-13-2002, 06:42 PM
DanHouck's Avatar
Quoted: 64 Post(s)
It takes a lot of dirt to really cut down on the picture. I use preventative medicine and keep my lens cap on when not in use and use canned air to blast dust off each time I use projector.
Dan
My HT is an oldie but goodie!
DanHouck is offline
post #7 of 9 Old 05-13-2002, 08:21 PM - Thread Starter
Lebowski's Avatar
Thanks for the replies.
So how often do you guys clean your lens?
I've had mine for about a month and a half and haven't cleaned it yet.
I only notice dust on it when its running and you can see the dust floating around near the lens.
Lebowski is offline
post #8 of 9 Old 05-14-2002, 09:32 AM
anthonyc's Avatar
if you use a lens cleaning solution allways apply it to the cleaning cloth or wipe. Never apply cleaning solution, spray, foam directly to the lens as it will run to the edge of the glass and accumulate there over time.
anthonyc is offline
post #9 of 9 Old 05-14-2002, 10:02 AM
bsd
bsd's Avatar
Eyeglass cleaning solution and a wipes meant for use on eyeglasses seem to work well. They are specifically designed not to scratch the glass.
-Brett
bsd is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
