Panasonic PT-AX100U Drops HDMI Signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-20-2012, 12:55 PM - Thread Starter
wilsonrio's Avatar
I am not sure if it is HDMI HDCP handshake compatibility or not.
Issue:
Projector shows HDMI image and consistently drops HDMI signal around 30-40 seconds later, lamp goes into solid orange (power is switch off and cooling lamp). The lamp has around 400 hours and after power cycling 4-5 times consecutively the projector shows HDMI image for hours without dropping signal. Also note that whenever I use VGA no signal problems at first start or anytime later.
Not Working Configurations:
PlayStation 3 (slim)---> 25 feet cable (BJC* Series-1)---> PT-AX100U
PlayStation 3 (slim)---> 6 feet cable (BJC Series-FE)---> PT-AX100U
Blu ray (LG)---> 25 feet cable (BJC Series-1)---> PT-AX100U
Blu ray (LG)---> 6 feet cable (BJC Series-FE)---> PT-AX100U
*BJC = Blue Jeans Cable
PlayStation 3 (slim)---> 25 feet cable (BJC* Series-1)---> SAMSUNG (2280HD)
PlayStation 3 (slim)---> 6 feet cable (BJC Series-FE)---> SAMSUNG (2280HD)
Blu ray (LG)---> 25 feet cable (BJC Series-1)---> SAMSUNG (2280HD)
I value the AVS Forum brainpower.
Wilson
wilsonrio is offline
post #2 of 7 Old 09-07-2012, 08:53 AM
mirage1000's Avatar
hi - Were you able to fix the problem. I just started having this problem. My Roku, Denon radio work fine.
But there is a loss of HDMI signal when i connect to my blu ray player. I only have 1 HDMI cable from receiver to projector.
mirage1000 is offline
post #3 of 7 Old 09-07-2012, 10:18 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
The original poster was probably experiencing a failure of the A-P.C board which handles the HDMI input. If your AX100U is working fine with everything except the Blu-ray player it's a different problem.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #4 of 7 Old 09-10-2012, 02:06 PM
mirage1000's Avatar
HI - its working fine even when I play blu-ray movies in my blu ray player.
BUT when i try to go to the apps in the blu ray player like net flix etc - it's losing the HDMI signal.
do u know what might be causing this?
post #5 of 7 Old 09-11-2012, 08:25 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Have you tried checking for a firmware update for your Blu-ray player? You didn't mention the brand and model but you'll likely get better answers in the Blu-ray Players forum.
http://www.avsforum.com/f/149/blu-ray-players
Mr.G is offline
post #6 of 7 Old 09-11-2012, 08:52 AM
mirage1000's Avatar
Its a samsung bd6500 with bult in wi-fi
post #7 of 7 Old 09-11-2012, 09:10 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Post your question here.
http://www.avsforum.com/t/1227336/samsung-bd-c6500-bluray-player
The latest firmware for this player was in January 2012.
Mr.G is offline
