When will we see 4K under $3K? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-22-2012, 08:10 AM - Thread Starter
Markov's Avatar
I am thinking about upgrading my current 720p pj (Panasonic PT-AX200U) to the either the Panasonic PT-AE7000U or JVC DLA-X30. This is a pretty significant purchase for me so I want to be happy with it for some time (~4yrs).
That being said, when do you think 4K projectors will be available for around $3k street price? If it's less than 2 yrs from now perhaps I should just stick with the PT-AX200 till then...
Markov is offline
post #2 of 16 Old 03-22-2012, 08:38 AM
iolmaster's Avatar
Who cares, there won't be any 4K material to watch in that time frame.
iolmaster is offline
post #3 of 16 Old 03-22-2012, 09:02 AM - Thread Starter
Markov's Avatar
When I bought my 720p pj that's exactly what was said about 1080p material...
Markov is offline
post #4 of 16 Old 03-22-2012, 09:35 AM
mariokrt64's Avatar
Quoted: 34 Post(s)
Not anytime soon....
mariokrt64 is offline
post #5 of 16 Old 03-22-2012, 10:03 AM
Amber Ale's Avatar
At least 8 or 9 years, would be my guess.
Amber Ale is offline
post #6 of 16 Old 03-22-2012, 11:15 AM
iolmaster's Avatar
Huh? I had an HD DVD player when I bought my AX200 4 and a half years ago. That was a 1080p source even then.
post #7 of 16 Old 03-22-2012, 03:37 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
April 1st, 2016 at 1:35.51 pm (that is in milliseconds).
That is when you will see 4k sources to the consumers in mass. If I am wrong, I will pay for your HT gear for the next 500 years (there is a 75-year waiting period to take advantage of this offer).
Hope that helps...
Access HERE from this thread
coderguy is offline
post #8 of 16 Old 03-22-2012, 03:48 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
I'm more concerned about a 1080p LED under $2k
blee0120 is online now
post #9 of 16 Old 03-22-2012, 07:58 PM - Thread Starter
Markov's Avatar
Ok I believe my memory was a little fuzzy, it was in fact 2 years earlier when I purchased my 720p LCD TV. Nontheless, and I know no one here can predict the future, I just wanted to get some impressions on if/when you think 4K will become mainstream.
Markov is offline
post #10 of 16 Old 03-22-2012, 08:01 PM - Thread Starter
Markov's Avatar
I will definitely take you up on that!
Markov is offline
post #11 of 16 Old 03-22-2012, 08:03 PM
ccotenj's Avatar
Liked: 101
a long time...
and unless you have a unique setup (which some do), it will be of no value to you anyway...
- chris
ccotenj is offline
post #12 of 16 Old 03-22-2012, 08:35 PM - Thread Starter
Markov's Avatar
I had also circumstantially heard that at >10' viewing distance that 4K would offer little refinement over 1080p (except maybe in 3D)
Markov is offline
post #13 of 16 Old 03-22-2012, 08:46 PM
Ericglo's Avatar
Quoted: 1699 Post(s)
Liked: 797
Well, JVC, Sony and DLP all have 4k panels. If Epson can get their LCOQ panels refined, then they should be up to 4k in the next two years or so. The Sony 1000 is around $20k street. I could see $5k to $10k 4k pjs in the next 2 to 3 years. After that, less than $3k could be 1 to 3 years after that. Unless you sit less than 1 screen width away, 4k shouldn't be a big priority. Led and laser should be more important.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #14 of 16 Old 03-22-2012, 10:32 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
coderguy was a year, 7 weeks, and 13 minutes early.
lespurgeon is offline
post #15 of 16 Old 03-22-2012, 10:49 PM
Rexas's Avatar
I think it's 3-4 years away. Maybe 5 years.
Rexas is offline
post #16 of 16 Old 03-23-2012, 01:09 AM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
This fall $15k, then in two years $10k, 3 years $5k, 4 years under $3k
