Strange remote control issue - Epson 3010 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-26-2012, 06:34 PM - Thread Starter
GG2
GG2's Avatar
Wondering if anyone else experience what I have or have a solution.
I just got the 3010 and put it in a shelf in my AV closet, projecting through the wall. The wall opening is 8x10 and the front IR eye is not blocked. The remote IR bounces very well from the front wall to the projector behind the back wall - except when I need to turn the unit on from Standby. It responds perfectly to every command when the unit is on.
But for the life of me, I can't turn it on with the remote. I even climb on the couch and stick the remote right up the projector face. I point it inside the closet to the back IR eye. Nothing. The only thing that works is me climbing a stool and hitting the blue button by hand.
There must be something I'm doing wrong?
GG2 is offline
post #2 of 21 Old 03-26-2012, 08:16 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Are you using the provided Epson remote?
Have you tried changing batteries?
2016
42Plasmaman is offline
post #3 of 21 Old 03-26-2012, 09:08 PM - Thread Starter
GG2
GG2's Avatar
Yes, it's an Epson remote and it is brand new. Can't be the batteries because the commands work flawlessly - even controlled my Panny BluRay. It works once the unit is on, but I just can't get it to come on from standby. Really strange.
GG2 is offline
post #4 of 21 Old 03-27-2012, 12:09 PM
Quoted: 20 Post(s)
Liked: 37
1. Make sure Direct Power On is off under the Extended settings.
2. Make sure HDMI Link is disabled - click HDMI link button on remote and disable/off
2016
post #5 of 21 Old 03-30-2012, 05:50 PM - Thread Starter
GG2
GG2's Avatar
Thanks. Will give it a shot.
GG2 is offline
post #6 of 21 Old 04-04-2012, 07:31 PM - Thread Starter
GG2
GG2's Avatar
Nope. Didn't work. Same issue. Won't power on with remote, but remote works perfectly once the unit is on.
GG2 is offline
post #7 of 21 Old 04-05-2012, 07:53 AM
Quoted: 20 Post(s)
Liked: 37
Do you have a programmable remote like the Harmony?
You could have it configured for the 5010(using the Epson 8350 template will work if the 3010/5010 is not in the database).
I wonder if may be the remote On switch is bad.
IIRC, the Epson remote has a button for ON and OFF/Standby.
If a programmable remote does not work, I suspect that maybe the IR sensor on the projector is not working/listening while in Standby.
2016
post #8 of 21 Old 04-05-2012, 06:27 PM - Thread Starter
GG2
GG2's Avatar
Yes, I've tried both the Harmony & Epson remotes (the 3010 is in the database) and neither work off standby. There must be a way to wake it from standby. Really odd.
GG2 is offline
post #9 of 21 Old 04-06-2012, 01:31 AM
riddle's Avatar
I have some issue with EH-TW6000, but when i will switch power on cabel of-on remote controler works perfect. Realy wierd
riddle is offline
post #10 of 21 Old 04-06-2012, 07:47 AM - Thread Starter
GG2
GG2's Avatar
Interesting. My cable box is on all the time too, and is connected to the 3010 by HDMI. That must be it. I'll play around with the Harmony settings for the cable box and see if it fixes it.
GG2 is offline
post #11 of 21 Old 04-06-2012, 08:06 AM
Quoted: 20 Post(s)
Liked: 37
Another thing to try is disconnect all cables from the projector and then see if it turns on.
If it does, I suspect it's getting some sort of command or a control line to not power up via the HDMI connection but HDMI Link disabled/off should have fixed this if it's the issue.
2016
post #12 of 21 Old 04-12-2012, 06:47 PM - Thread Starter
GG2
GG2's Avatar
Disconnected the cables, but still didn't power up. Using both the Epson & Hramony remotes. Still doesn't power up from remote. Strangely though is that it powers up by remote within a couple of minutes of being turned off. So after a certain period it goes into some strange suspend mode where the remote doesn't wake it.
GG2 is offline
post #13 of 21 Old 04-13-2012, 12:25 AM
riddle's Avatar
You got it via UPS? I rebooted yesterday UPS and it's OK. Very strange.
riddle is offline
post #14 of 21 Old 04-18-2012, 07:40 AM - Thread Starter
GG2
GG2's Avatar
I think I solved it. Good hunch. The projector was connected to a Monster power conditioner. After I connected it directly to the wall outlet, the remote works. There must be something about the power signal from Monster that affects the IR signal at standby.
GG2 is offline
post #15 of 21 Old 04-18-2012, 08:04 AM
Quoted: 20 Post(s)
Liked: 37
Wow, that's a new one.
What model Monster UPS?
2016
post #16 of 21 Old 04-18-2012, 08:28 AM - Thread Starter
GG2
GG2's Avatar
It's the Monster Reference Powercenter HTS 3500
GG2 is offline
post #17 of 21 Old 05-06-2012, 05:54 PM
stephen kerr's Avatar
Hi, I found your post whilst trying to find a reason why my Epson is having remote control issues. I have had it replaced but the new unit has the same problems. Sometimes it will not switch on, needs the power button on the projector pressed or the power cycled off/on. I am not using a power conditioner. Any information gratefully received.
Stephen
stephen kerr is offline
post #18 of 21 Old 05-08-2012, 02:07 AM
Larry Ng's Avatar
I have the same problem with my 6010 , after a few days' standby , it would not power on remoted , need pushing the pw button , not so if I light it up everyday , strange but I now don't see this an issue , just live with it and assume it as a safety measure the PJ offers .
Updated to 104 , still the same .
Larry
Larry Ng is offline
post #19 of 21 Old 07-14-2012, 11:36 PM
nanochow's Avatar
I have the same problem with my 5010 not turning on via remote when the unit is left off for a few days. Epson has been kind enough to send me a new remote and also a replacement projector, but unfortunately the problem still remains. I will call them up again next Monday.
nanochow is offline
post #20 of 21 Old 07-29-2012, 05:23 PM
Roger16's Avatar
Larry
It's a big issue if your projector is mounted on a 15 ft ceiling and the pw button can only be accessed by a long ladder. i have the same issue not powering on when not used for a few days.We have the Epson 6010 and this is something that Epson must fix.
Roger16 is offline
post #21 of 21 Old 07-31-2012, 07:59 AM
Quoted: 20 Post(s)
Liked: 37
