DLP ghosting with computer but not dvd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-28-2012, 07:18 PM - Thread Starter
sstockfo's Avatar
I have a Optoma pro 250dx dlp projector. I have a computer with component option pushed through the seven pin s-video port on the video card. This then goes into my Sony AV Receiver, then it goes into a component-vga cord into my projector where the projector reads the component signal in the vga1 port. I also have a dvd player component into the AV receiver then to the same cord to the projector.
Problem is that when using the computer, I get ghosting, but the DVD is perfect (so it can't be the cord) and the projector menu is perfect. My computer is older, so I am first to suspect the ability of the video card to do a good job.
Any thoughts?
sstockfo is offline
post #2 of 5 Old 03-29-2012, 04:34 AM
shane2943's Avatar
Any thoughts?
The S-Video cable from the computer to your receiver is where I'd start. Can you use another interface? S-Vid from a computer is most times not a desirable option. What inputs types does your A/V receiver have to work with? Any VGA?
shane2943 is offline
post #3 of 5 Old 03-29-2012, 09:02 AM
PLB
PLB's Avatar
Whenever I have a problem with ghosting I suspect Indian burial grounds.
PLB is offline
post #4 of 5 Old 03-29-2012, 11:47 AM
shane2943's Avatar
post #5 of 5 Old 04-03-2012, 01:59 PM
golfnz34me's Avatar
Using an S-Video cable to connect your PC to your Receiver is going to give HORRIBLE results. S-Video was designed for old analog TV's with real resolutions of 320x240.
You need to at least go to a Component (3-Wire) connection in order to get good results.
It's toe-tappingly tragic!
golfnz34me is offline
