8ft throw - AVS Forum | Home Theater Discussions And Reviews
Old 04-05-2012, 06:50 PM - Thread Starter
BradSut6's Avatar
Im going to have about an 8 ft throw for my epson 8100. what size screen should i build for it?
BradSut6 is offline
Old 04-05-2012, 07:04 PM
wormraper's Avatar
Quoted: 315 Post(s)
Liked: 161
use the throw calculator here on PJC
http://www.projectorcentral.com/Epso...ulator-pro.htm
at 8 feet fully zoomed out you can get about 83 inches most likely
wormraper is online now
Old 04-05-2012, 08:18 PM - Thread Starter
BradSut6's Avatar
zooming has no effect on quality right?
BradSut6 is offline
Old 04-06-2012, 11:38 AM
wormraper's Avatar
Quoted: 315 Post(s)
Liked: 161
you loose a little bit of lumens and pq with zooming due to distance but this is zoomed OUT , zooming happens the FARTHER you're away from the screen. you're uber close so you're literally the most unzoomed you can get and you're still barely getting 83 inches
