"brilliant color" on or off? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-09-2012, 01:39 PM - Thread Starter
CaptJosh's Avatar
Brilliant color seems to add a yellowish tinge with my acer 7531d. Using dalite matte white 106"....can't seem to calibrate the yellowness out. Using spears and munsell calibration disc. Anyone have this issue?
CaptJosh is offline
post #2 of 10 Old 04-09-2012, 02:57 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Brilliant Color should always be off for a true image. At least that's what all the experts/calibrators say. You could verify this in the Calibration section here.
Jim McC is offline
post #3 of 10 Old 04-09-2012, 04:29 PM - Thread Starter
CaptJosh's Avatar
I agree. Sometimes, the contrasty stuff it adds isn't too bad, but I feel like it's leaning the temp of the color a good bit.
CaptJosh is offline
post #4 of 10 Old 04-09-2012, 05:05 PM
jamieuk147's Avatar
Quoted: 69 Post(s)
I think it looks better on adds more depth to the image
jamieuk147 is offline
post #5 of 10 Old 04-09-2012, 07:07 PM
Airion's Avatar
Liked: 61
I used brilliant color at first on my Mitsubishi HC3800, but I noticed some artifacts. For example, a red brick wall would turn into an orange blob with brilliant color. Other projectors might handle it differently, but I don't trust brilliant color.
Airion is offline
post #6 of 10 Old 04-09-2012, 08:15 PM - Thread Starter
CaptJosh's Avatar
Sometimes, it seems *more* natural, other times it doesn't....but in any event, I guess that's not what the filmaker intended.
CaptJosh is offline
post #7 of 10 Old 04-10-2012, 02:00 AM
btiltman's Avatar
When I first got my Mits HC-3800 I played with Brilliant Color a lot. It makes it very difficult to calibrate the projector properly and if you do get it close it produces bad artifacts in the bright whites. (Flaring pixalization effects)
btiltman is offline
post #8 of 10 Old 04-10-2012, 03:46 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
It does vary from projector to projector. I've had 3, here are my experiences,
Mits HD1000U: Mainly just pumps up the whites, so you get an unbalanced image with overly bright highlights. No benefit IMO.
Infocus X10: Works better than the 1000U, but adds the odd pixelization in whites unless you reduce contrast quite a bit. Not worth it here either IMO.
Benq W6000: I'm actually using it with this one. Whites are ok and it does boost brightness across the board. In outdoor bright scenes I actually prefer it. Calibration still isn't as good though. In particular, light blue colors (think light blue sky, maybe water/ocean) are off and I can't find a way to fix them 100%.
I'm only using it with the W6000 because I have a large 1.0 gain screen and the extra brightness trumps the modest calibration problem (personal taste, some won't agree). Eventually I may get a higher gain screen and stop using it, although it does really look good in brighter scenes.
talon95 is offline
post #9 of 10 Old 04-10-2012, 02:05 PM - Thread Starter
CaptJosh's Avatar
That's sorta where I am at. The outdoor scenes do look good. In many ways, more natural...but I see other areas....low light, inside, ect. Where it looks off. The thing of it is, I can't seem to dial it in right(eg, other adjustments that bring it back to being closer to being calibrated)
CaptJosh is offline
post #10 of 10 Old 04-11-2012, 03:55 AM
KnightRT's Avatar
In my experience with an HC3800, any settings that preserve the brightness boost of Brilliant Color also posterize the image. At least for that projector, it's better left off.
KnightRT is offline
