Looking for a 2d projector ( short throw/ regular ) is okay - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-14-2012, 01:31 PM - Thread Starter
audionewer's Avatar
i am looking for a 2d projector with a 100inches screen. right now i got a hd33( 3d bluray/movies).
i am thinking to buy a projector for 2d cause hd33 got a RBE when i watch 2d movies.
please give me some idea.
12x10ft
audionewer is offline
post #2 of 10 Old 04-14-2012, 05:27 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
It sounds like you need to switch to LCD. What's your budget?
Jim McC is offline
post #3 of 10 Old 04-14-2012, 07:15 PM - Thread Starter
audionewer's Avatar
If it is LCD, then i might just get 3010 pj.
the problem i have to sell it or return it
post #4 of 10 Old 04-15-2012, 12:35 AM
invadergir's Avatar
Quoted: 42 Post(s)
So the RBE doesn't come into play when you are watching a movie in 3D?
If you go LCD then the 8350 would be more than enough to handle the 100" screen at your distance. If you are exchanging the projector for another 3D LCD for the cheap than i would think the 3010 would be next option.
My DVD Collection
HOME THEATER:
Sony 40ES 3D Projector, 106", Samsung 51" 3D Plasma, Marantz sr7010 in 5.2.4 Atmos/DTS:X
invadergir is offline
post #5 of 10 Old 04-15-2012, 01:29 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
It's extremely rare to see enough RBE to be bothersome on a 6x color wheel, are you sure you have the Optoma hd33 in max color speed mode?
Access HERE from this thread
coderguy is offline
post #6 of 10 Old 04-15-2012, 07:38 AM - Thread Starter
audionewer's Avatar
how do i know if the hd33 is in max color speed mode?
the lamp is on std mode ( 2d and 3d)?
post #7 of 10 Old 04-17-2012, 01:17 AM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
I am not sure for the hd33.
Are you watching the image too bright?
An overly bright image will cause RBE for people even when a properly calibrated image at correct brightness levels will not.
coderguy is offline
post #8 of 10 Old 04-17-2012, 05:49 AM - Thread Starter
audionewer's Avatar
i use cvh setting for 2d and 3d right now.
post #9 of 10 Old 04-17-2012, 11:22 AM
necroticart's Avatar
You could always try an ND2 filter to cut down on the brightness but as always look at your settings first
necroticart is offline
post #10 of 10 Old 04-17-2012, 12:46 PM
Rob-Houston's Avatar
Quoted: 121 Post(s)
Liked: 67
Try this link for as a starter http://www.projectorcentral.com/opto...tor_review.htm
Rob-Houston is offline
