Viewing life of RPTV vs PJ - AVS Forum | Home Theater Discussions And Reviews
Old 05-14-2002, 10:30 PM - Thread Starter
Delmonte's Avatar
I was wondering what the expected life of an RPTV is versus HT projectors. Some projectors (you know who) boast 5000 hours of lamp life.
How long would the bulbs in a RPTV last?
I am deciding upon a new diplay device for my dedicated HT and really want a projector (in the 3k - 4k range), but want to be sure I'm not spending $500+/year on lamps. If RPTV's don't last 10x longer, it will make my decision easier... though I can't see NOT having at least an 8' screen...
Doug
Delmonte is offline
Old 05-14-2002, 11:28 PM
ADebar's Avatar
when you say RPTV do you mean CRT-based, LCD-based, or DLP-based RPTV? all of those RPTVs will have different lifespans. DLPs do have bulbs, but they will last longer than a DLP-based projector because they do not need to be run as bright. CRT-based RPTVs have phosphor "guns" that wear, or "burn", with age. after 5 years you will notice a duller picture. i'm not too up to speed on my LCD-based RPTVs :(
:p
ADebar is offline
Old 05-15-2002, 02:46 PM
Namlemez's Avatar
Almost all RPTVs out there are CRT projectors right now...
That being said, the manuals usually have a MTBF in them (Mean Time Between Failure) which is basically how long the average one lasts. As ADebar said, the brightness starts dropping before that. I think the low-end for MTBF on most RPTVs is like 10,000 hours.
Namlemez is offline
