Quick AR100 and 8350 Question - AVS Forum | Home Theater Discussions And Reviews
Old 04-20-2012, 08:15 AM - Thread Starter
snapware's Avatar
Would both the Panasonic AR100 and Epson 8350 both be easy to put on a projector mount and perfectly align the viewing screen to a projector on the wall?
Do you have any tips for this process or anything I should know?
snapware is offline
Old 04-20-2012, 10:07 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Will this be a ceiling mount or wall mount?
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Old 04-20-2012, 11:11 AM - Thread Starter
snapware's Avatar
I am planning to do a ceiling mount
snapware is offline
Old 04-20-2012, 08:07 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
yes, within reasonable limits (projector within screen area and horizontally near center) both are easy.
lespurgeon is offline
Old 04-21-2012, 11:40 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Originally Posted by snapware View Post
Would both the Panasonic AR100 ... be easy to put on a projector mount and perfectly align the projector to the viewing screen on the wall?
As the previous poster states the AR100U is easy to install on a projector mount and align to the screen. In my installation I used a Peerless mount (I'm a big fan of), Peerless ceiling plate and Peerless adjustable extension column. By the way you can buy these in either black or white.
Mount:
http://www.amazon.com/Peerless-PRGUN...5028870&sr=8-1
Ceiling plate:
http://www.amazon.com/Peerless-Indus...5029197&sr=1-1
You can purchase a Peerless extension column or build your own to length using PVC pipe as suggested by MississippiMan.
Here is a picture I took while installing mine.
Mr.G is offline
Old 04-23-2012, 07:44 PM - Thread Starter
snapware's Avatar
Thanks guys, I'll assume the Epson can mount the same way too?
snapware is offline
