Looking for older firmware. - AVS Forum | Home Theater Discussions And Reviews
Old 04-22-2012, 12:07 PM - Thread Starter
Bohanna's Avatar
Liked: 24
Hi all,, I am looking for the firmware for an older Ask-Proxima DP6155,,,AKA the ASK C105 AKA the infocus LP690. I went to the infocus site and the firmware version they have for the machine screwed things up big time. The projector went from a great picture to one that has a serious convergence problem,
if anyone has or knows where I can find an earlier version of the firmware could you please post the info here??
ANY help would be greatly appreciated
Many Thanks in advance
Bohanna
Bohanna is offline
Old 11-21-2012, 11:20 AM
Yetanfou's Avatar
Are you still looking for this firmware? Which version did you send to the projector? I have a version called 'C105_DP6155_LP690_805280E.bin' if that helps.
Do you have the remote control to this thing? I need the remote control codes used by it, as I need to get my DP6150 (which uses the same RC) needs service (see http://www.avsforum.com/t/1439828/proxima-dp6150-ask-c100-purple-line-right-yellow-shift-left). If you have it you can extract the codes (I can help with that) so I can teach one of my PCs or phones to play-act remote control to the thing.
Yetanfou is offline
Old 11-21-2012, 04:27 PM - Thread Starter
Bohanna's Avatar
Liked: 24
Hey Just saw this thread that I started again,
The Firmware you want for the 6150 is
C100v805262H
I'm guessing you tried the 6155 flash and this caused a problem!
Bohanna
Bohanna is offline
Old 11-21-2012, 05:17 PM
Yetanfou's Avatar
No, I did not try to flash this machine. I've just been looking for firmware files to see if I could pull them apart to find a way to get into the service menu without having the remote control. I also have the correct firmware for the 6150, but have not felt the need to update it as I don't really think the problems are caused by 'old' firmware...
The firmware binaries are obfuscated so I first have to get through that...
Yetanfou is offline
