Throw distance confusion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-23-2012, 12:56 PM - Thread Starter
brado32's Avatar
Sorry for the newbie question.. I am in the market for a new projector..
I have the Sony Pearl (VPL-VW50) and looking at alternatives.
I am confused by the throw distance calculator over at Projector Central.
Currently, My sony is only 11'6" from lens to screen. My screen is 52X92 = 106'diag
According to the calculator, this shouldnt work. Been filling the screen with this setup for years.. what am I missing??
thanks
-Brad
brado32 is offline
post #2 of 5 Old 04-23-2012, 08:45 PM
kimsharma's Avatar
IIRC the calculator gives you throw / size / seating distance calculations based on default zoom / screen illumination in fl / etc etc (extra etc thrown to cover my ignorance).
However, and this is where you are in luck, you can manually adjust the zoom if you want a larger / smaller picture size. I had a similar question and realized that the calculator is a guideline.
Hope this helps.
kimsharma is offline
post #3 of 5 Old 04-26-2012, 08:33 PM
Muse's Avatar
Quoted: 31 Post(s)
Yeah, I just used the calculator for the first time. Am looking at the Epson 8700ub which has a zoom range of 2.10:1. The calculator assumes a zoom in what I think is the exact middle of that range, 1.55. That appears to be not adjustable in the calculator. It strikes me as strange and I posted a message to their staff. Seems to me they could have a slider for the zoom desired, would be a lot more useful.
Muse is offline
post #4 of 5 Old 04-27-2012, 12:26 AM
rujo's Avatar
When I look at/use that calculator - the zoom is adjustable by moving the arrow in the "zoom" box.
rujo is offline
post #5 of 5 Old 04-27-2012, 04:32 AM
Muse's Avatar
Quoted: 31 Post(s)
Oh, somehow I missed that. Thanks!
Muse is offline
