Vacuum Cleaner on Projector? - AVS | Home Theater Discussions And Reviews
post #1 of 2 Old 04-27-2012, 08:41 AM - Thread Starter
WeiJie463's Avatar
Hi,
Can I use a vacuum cleaner to clean my projector?
WeiJie463 is offline
post #2 of 2 Old 04-27-2012, 01:51 PM
mariokrt64's Avatar
If you have to clean a filter, need to be very carefull...I had cleaned mine several times with the vacuum cleaner, but the last time it sucked it in and broke it. So I had to get a new one.....for the PJ casing itself, I used a very lightly damped cloth with much care not to touch sensitive parts.....
The JVC manual states not to use cleaning liquids on the lens so I have used a very delicate brush to brush off the dust......
check your user guide to check what they recomendt..
mariokrt64 is offline
