Projector and screen shopping - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-30-2012, 04:43 PM - Thread Starter
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
I would like to get a 120-130 inch picture out of my projector. I can do anything to the room to make it fit the needs of the projector and screen. I have been doing some research and it seems that DLP is the way to go but I am not opposed to LCD or anything else. I would like to go 2.35 one day but 16:9 will do for now. I have a budget of about 3k for the projector and screen. Also i can mount the projector as needed.
Thanks for the help
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #2 of 7 Old 04-30-2012, 05:53 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
Do you want 3D or gaming?
I would say go for the Benq w7000 or Sony hw30 if you do gaming, if not maybe go for the JVC RS-45.
Access HERE from this thread
coderguy is offline
post #3 of 7 Old 04-30-2012, 06:10 PM - Thread Starter
Quoted: 978 Post(s)
Liked: 506
Sorry I knew I forgot something. This will be for HT. I want a good 2D projector and the 3D will be secondary as I dont own any 3D movies. Also can you recommend and good screen to go with the projectors you recommend. Thanks
post #4 of 7 Old 05-01-2012, 03:25 PM - Thread Starter
Quoted: 978 Post(s)
Liked: 506
any more help?
post #5 of 7 Old 05-01-2012, 08:02 PM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
Given the budget and screen, I would go with a Benq w7000 and pair it with a DA-Lite high Power screen, you will probably need an ND filter to tame the brightness at first. This will maximize longevity of the lamp.
The other options are out of your budget for both screen + PJ.
coderguy is offline
post #6 of 7 Old 05-01-2012, 08:06 PM
Mike Garrett's Avatar
Quoted: 5605 Post(s)
Liked: 3588
Originally Posted by Pain Infliction View Post
any more help?
Give us a call and we can discuss what would best fit for you in your price range.
mjgarrett100@gmail.com
Mike Garrett is offline
post #7 of 7 Old 05-02-2012, 08:13 AM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Are you sure you and anyone else who will be exposed to the projector is not RBE / rainbow sensitive?
Most of the time RBE is subtitle but for some it could be bothersome.
http://en.wikipedia.org/wiki/File:DL...bow_effect.JPG
If you're not sure and you decide to get a DLP, make sure you get one that has a good return policy.
2016
42Plasmaman is offline
