Abis lxled 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-07-2012, 02:30 AM - Thread Starter
Honzik1's Avatar
Quoted: 17 Post(s)
What do you think about this projector?
ABIS LXLED 2
http://www.projectorsite.co.uk/index...=133&parent=26
Thanks for posting your opinions here!
Honzik1 is offline
post #2 of 4 Old 05-08-2012, 12:21 AM
vilfrard's Avatar
http://www.youtube.com/watch?v=vspwGITHYi8
Technical Specifications:
Resolution: 1280 x 800 native, Full HD 1080p compatible
Brightness: 2,600 Lumens
Contrast Ratio: 3500:1
Aspect Ratio: 4:3 or 16:9 (note: older version projectors do not have 16:9)
Picture Size: 30" - 450"
Zooming: Digital and Manual
Fan Noise: Standard (average 20db to 30db)
specs look good but for the price I would rather have a Optoma ml500 or a ViewSonic PLED-W500
vilfrard is offline
post #3 of 4 Old 05-08-2012, 12:52 AM - Thread Starter
Honzik1's Avatar
Quoted: 17 Post(s)
You would buy ML500 instead of this with 2600 lumens? I am not sure if I can trust these specification, what do you think?
Honzik1 is offline
post #4 of 4 Old 05-08-2012, 11:22 AM
rovingtravler's Avatar
If you really think this thing outputs 2600 lumens you will be in for a big suprise. These are the LED specs for output not the actual light output from the projector lens. CRE does this... they list the specs of components and not the projector.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
