Streaming video to a projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-14-2012, 06:44 PM - Thread Starter
bush224's Avatar
I am looking to use an existing projector which does not accept HDMI only component in my game room.
I want to be able (because of location) to stream from a standard def cable box to the projector about 30-ish feet away.
What is the best way to do this?
I have see the HDMI remote streamers but the projector only accepts component.
I can NOT run any cables where I want to hang the projector.
bush224 is offline
post #2 of 4 Old 05-14-2012, 08:16 PM
rovingtravler's Avatar
They sell HDMI to Coomponent convertors.
Does it accept DVI?
I am not recommending this one... it is just the first one I found, but they are not too pricing. This with an HDMI wireless system might work... Is the Projector HDCP compliant? Not sure if that will be an issue for EDID.
http://www.overstock.com/Electronics/HDMI-to-Component-Converter-6-foot-HDMI-Cable/6055589/product.html?cid=202290&kid=9553000357392&track=pspla&kw={keyword}&adtype=pla
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #3 of 4 Old 05-15-2012, 03:54 PM - Thread Starter
bush224's Avatar
No... it is a Panasonic PT-L300U. It is not HDCP compliant.
Does that mean the HDMI to component will NOT work?
bush224 is offline
post #4 of 4 Old 05-16-2012, 10:56 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
If you are trying to stream SD cable TV (480i) to the PT-L300U (native resolution 960X540) just find yourself something that will stream 480i, the projector will do a slight upscaling but it will still look mediocre at best. As an aside, your projector will accept a 1080i, 720p signal but will scale it down to its native resolution so as you probably already know it's not really an HD projector.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
