Need help choosing a projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-24-2012, 04:14 AM - Thread Starter
Bryceo's Avatar
Need help choosing a 3d projector
Bryceo is offline
post #2 of 11 Old 05-24-2012, 05:42 AM
blee0120's Avatar
Quoted: 646 Post(s)
Liked: 327
How much are you trying to spend?
blee0120 is offline
post #3 of 11 Old 05-24-2012, 06:02 AM - Thread Starter
Bryceo's Avatar
No more then 5000
Bryceo is offline
post #4 of 11 Old 05-24-2012, 01:12 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
Still need a lot more info...
What are your viewing habits, your screen size, seating position, do you need placement flexibility, are you also buying a new screen, etc?
I would look into the Epson 5010 or Sony hw30 as an all-around 2D/3D combo, if you want just absolutely the best 3D possible and don't care about 2D as much, then look at the Optoma hd33/hd3300, Optoma hd8300, or the Benq w7000.
Access HERE from this thread
coderguy is offline
post #5 of 11 Old 05-24-2012, 04:52 PM - Thread Starter
Bryceo's Avatar
I like action films, my screen size is adjustable up to 139" my seating is 12 feet away from the screen I have a dark room
Bryceo is offline
post #6 of 11 Old 05-24-2012, 05:32 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
I would probably go with the Epson 5010 based on the giant screen size because it will do better with 3D in its brighter torch modes. At this screen size, I would still look into the HP Da-Lite 2.4 gain screen even if going with the Epson, because that is a pretty big screen and you will need as much brightness as you can get over time for 3D.
coderguy is offline
post #7 of 11 Old 05-24-2012, 08:45 PM - Thread Starter
Bryceo's Avatar
I looked at a epson that was only 115" maximum for 3,999
Bryceo is offline
post #8 of 11 Old 05-24-2012, 09:39 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
I don't know what you mean...
coderguy is offline
post #9 of 11 Old 05-24-2012, 10:07 PM - Thread Starter
Bryceo's Avatar
My room size the first epson projecter I looked at didn't have a big span on it
Bryceo is offline
post #10 of 11 Old 05-24-2012, 11:07 PM
jnabq's Avatar
Liked: 39
You may be misunderstanding some of the information you got, or we're misunderstanding your question?
From the Epson 5010 FAQ page.
Q:
What image size can be projected?
A:
The projected image size is measured diagonally and can be from 30 to 300 inches (0.76 to 7.62 m). The size of the image is determined by the distance from the projector’s lens to the screen. Depending on your display settings, source signal, and how you use the Zoom ring, the actual size may differ. A utility to help calculate an image size or the projection distance is available from the Drivers & Downloads page for your projector.
jnabq is offline
post #11 of 11 Old 05-25-2012, 03:53 AM - Thread Starter
Bryceo's Avatar
Yeh I miss understood the question
Bryceo is offline
