looking for a backup 2d projector - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2012, 08:52 AM - Thread Starter
audionewer's Avatar
hi.
i just bought a HD33 for 3d movies. i also want to buy a pj for only 2D (1080p) movies. since hd33 pj got rainbow issues.
1. price range - less than $1000
2. 720p or 108p
3. screens is 100inches Favi 1.3gain
audionewer is offline
Old 06-01-2012, 10:57 AM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
Your RBE issues might mainly be because you are watching it too bright?
Even if someone isn't super RBE sensitive, a brighter image will show rainbows to many.
A refurb'd Epson 6500ub if they are still around (maybe not though), otherwise you could the Epson 8350. There are not a lot of good LCD choices around $1000 other than those two. There are some ok 720p Epson LCD's, but I am not that confident that their contrast is that great.
Access HERE from this thread
coderguy is online now
Old 06-01-2012, 11:02 AM
mbw23air's Avatar
Quoted: 158 Post(s)
Liked: 149
Originally Posted by audionewer View Post
hi.
2. 720p or 108p
I would look for a used JVC RS1 on either eBay or videogon.com. It will give you the best black level and pq for under $1k you can find plus replacement lamps aren't that expensive.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
Old 06-01-2012, 11:23 AM - Thread Starter
audionewer's Avatar
if u say that i might be watching tv shows & movies too bright then i need a good/best setting for my pj and screen.
Old 06-01-2012, 11:52 AM
coderguy's Avatar
Quoted: 322 Post(s)
Liked: 277
Buy an ND Filter, you can get one for under $50. That will reduce the brightness.
100" screen wtih 1.3 gain is going to be way too bright in 2d for the Optoma hd33, you're probably watching the thing at like 30 fL to 40 fL, almost everyone is going to see RBE at that brightness. That is just way too bright. You need to cut the brightness down by 40% to 50% with an ND filter. Even after you put the ND filter on, you may need to wait until the lamp wears in a little before the RBE goes away enough.
Old 06-01-2012, 05:49 PM - Thread Starter
audionewer's Avatar
can u please give me the sites to buy it please?
i know i need to use it for 2d. do i need it to use for 3d? right now it is on 200 hrs.
