LG PA70G Portable HD LED Projector 700 ANSI Lumens, 1280 x 800 WXGA - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 12-18-2012, 10:25 AM - Thread Starter
obxbeachbum's Avatar
redkrypton, might I suggest you ask your question on this thread: http://www.avsforum.com/t/1405666/lg-pa70g-led-1280x800-700-lumens/1020
It is getting a lot of traffic with very smart people using 3D.
I have not tried using 3D yet but I will probably get a nice video card and use my computer since I use a lot of movie rips, and working on XBMC box. Using a computer you have so many more option, TV card, gaming, picture slide shows etc. Anyway, try the link above and ask your question.
Good Luck !
obxbeachbum is offline
post #32 of 33 Old 01-07-2013, 04:03 AM
pathikrit's Avatar
Y hi i tried a lot with this LG PA 70G to start the 3 D movie but I dont know how it operates
I did everything but then i saw the comment
Can any one help
r
pathikrit is offline
post #33 of 33 Old 06-04-2013, 06:25 AM
Mchoraji's Avatar
I have been chasing the LG PA70G LED Projector since Dec 2012 and I finally got it in May 2013, used it for a week now.
IT IS PERFECT ... FOR 799$ , WORTH EVERY CENT.
It is small enough to carry and it carries a punch ! I get a fullHD image in my bedroom at around 100 inches and 200 inches in the living room for late night family viewing.
When brightness is at full you however have to have good sound so it will not be a distraction. No issue with focus nor zoom.
I am yet to use HDMI, I will when I get a graphics card that can candle 1080p native. VGA is doing okay and the best part is the USB Function that allows quick and easy storage play.
I am not sure which is clearer, via usb or HDMI. My family and friends are speechless and i second them.
This is just the 1st step to building my ultimate hometheater set-up.
I will make a DIY Projection screen in the course of next month and will let you know how that goes.
Well,here are the pics
Mchoraji is offline
Lg Electronics Pa70g Micro Portable Led Projector
