Using PS3 to play bluray 3d via Acer H5360bd. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-24-2012, 04:58 AM - Thread Starter
Projector3d1997's Avatar
When i play a bluray 3d on ps3 using H5360BD it come up 3d input not suported.Then it plays it in 3d black and white.Why is this?Is it because of the resolution?
Projector3d1997 is offline
post #2 of 6 Old 06-24-2012, 01:07 PM
man4mopar's Avatar
No experience with the H5360BD but do have a PS3 and a 3D H9500BD projector, I am assuming you have gone into the PS3 and enabled 3D and set screen size etc? Sounds like maybe you have if going into 3D but with black and white. Is it only with movies or do games do it as well?
man4mopar is offline
post #3 of 6 Old 06-25-2012, 06:32 AM - Thread Starter
Its only when i try to play a bluray 3d. I insert 7 wonders of the solar system 3d and it plays with no colour.
post #4 of 6 Old 01-23-2013, 02:32 PM
James Davidson's Avatar
I'm having a similar problem. 3D blurays only play in black and white when using the DLP 3D mode. The 3d effect is there, but just no colour. This is from my samsung bd-c5900 blu-ray player.
I've tried different cables but with no luck.
Other 3D content such as xbox 360 games run fine.
Did you ever find a solution, or has anyone got any ideas why it's not workin?
James Davidson is offline
post #5 of 6 Old 01-23-2013, 04:56 PM
Found a solution to my problem.
I just did a reset to default settings on the projector. Not sure why but that has solved the black and white image when in 3d DLP mode. It has also improved the image during bluray play back and the quality of the image from the Xbox 360.
I was starting to pull my hair out with that one, but hopefully this will help someone else in the future.
post #6 of 6 Old 01-23-2013, 09:38 PM
DragonSixGolf's Avatar
Liked: 25
I *think* i had this same problem on the reg 5360. It had to do with changing some color processing settings on the proj.. saturation etc. it's not connected now or i'd check but, like you said.. going to defaults fixes it.
DragonSixGolf is offline
