optoma HD20 not powering up need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-25-2012, 05:27 PM - Thread Starter
m335i's Avatar
I need help, my projector bump busted doing a movie, so i took the bulb out replaced it with a new bulb and it is now not turning on.
m335i is offline
post #2 of 6 Old 06-25-2012, 06:25 PM - Thread Starter
m335i's Avatar
Also projector does the same thing with lamp out of projector and in the projector.
m335i is offline
post #3 of 6 Old 06-25-2012, 08:29 PM
guitarman's Avatar
Quoted: 14 Post(s)
Pull the plug on it for five minutes then try it again.
Another thing make sure you have the lamp door on tight. There's a small piece of plastic on the door that releases the trigger point of the projector. That piece has to make contact or maybe it broke off, look it over make it tight.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #4 of 6 Old 06-26-2012, 10:10 AM - Thread Starter
m335i's Avatar
i tried going over everything and making sure all screws are in tact and still nothing... frown.gif
m335i is offline
post #5 of 6 Old 06-26-2012, 10:19 AM - Thread Starter
m335i's Avatar
EDIT NEVERMIND I FIXED IT THANK YOU!!!!!
m335i is offline
post #6 of 6 Old 01-29-2013, 01:38 PM
notqytryt's Avatar
how did you fix it I have the same problem
notqytryt is offline
