Ghetto mod mount with the Epson 3010 -- What can I do to fix my situation without spending more $$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-02-2012, 04:46 AM - Thread Starter
Zlatty's Avatar
Hi Everyone,
I recently got a Epson 3010. The projector is really neat for my living room set up. Unfortunately the lack of lens shift has made it a pain in the butt to mount.
I bought a wall shelf and thought I could mount it above the couch. Unfortunately, I did not fathom that ceiling/ high shelf mounts would mean that the projector needs to be up-side-down.
So right now, my projector is up-side-down on a towel on a nice looking shelf. Totally not pleasing to the eye.
700
How can I ratify this situation? Should I just spend big bucks for a proper ceiling mount? If so, what do you recommend? The Epson one is nearly $300!
Zlatty is offline
post #2 of 6 Old 07-02-2012, 10:22 AM
kevinmscs's Avatar
Quoted: 493 Post(s)
Liked: 208
kevinmscs is offline
post #3 of 6 Old 07-02-2012, 07:45 PM
jnabq's Avatar
Liked: 39
For very few dollars, maybe a diy using a satellite dish mount? http://www.avsforum.com/t/898322/diy-universal-mount
Zlatty likes this.
jnabq is offline
post #4 of 6 Old 07-02-2012, 08:44 PM
adude's Avatar
Quoted: 51 Post(s)
I used this mount.
http://www.monoprice.com/products/product.asp?p_id=6528
The arms are bit short for Epson. But a quick trip to Home Depot and bought the some door hardware that ended up extending the reach of the arms. This youtube video was the inspiration.
http://www.youtube.com/watch?v=J1dKKNplads
Zlatty likes this.
adude is offline
post #5 of 6 Old 07-02-2012, 09:28 PM
batutta's Avatar
Quoted: 16 Post(s)
Liked: 24
There was a post here where somebody just bought some rubber laptop feet and attached them to the top of the projector, so it could be put upside down on a shelf. Something like these--
http://www.amazon.com/Sorbothane-Hemisphere-Non-Skid-Adhesive-Durometer/dp/B003IMSIBA/ref=pd_bxgy_e_text_b
Zlatty likes this.
batutta is offline
post #6 of 6 Old 07-03-2012, 04:34 AM - Thread Starter
Zlatty's Avatar
Oh nice! The only thing is, you still have to prop the projector if your alignment is not dead on.
Zlatty is offline
