non-anamorphic LT-150z - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-20-2002, 06:25 PM - Thread Starter
KO Abear's Avatar
Location: Brusly, Louisiana (just upriver from New Orleans)
Ive been enjoying my 150z immensely in the 3 months ive had it...but I'm still confused about a couple of issues. The first concerns non-anamorphic letterboxed dvd's. I usually leave the pj running in cinema mode (16x9) to take advantage of anamorphic movies...and I also select the 16x9 display output mode on my sony 7000 dvd player...but when I am watching a non-anamorphic dvd...do I convert both the pj and dvd players settings back to 4:3 mode or can I just leave them set where they are? How does leaving as is affect the picture quality? I also wonder why, when the movie is a wider aspect ratio than 16x9, that the letterbox bars produced by my dvd player are much lighter than the ones the pj produces to mask off the screen at 16x9. Thanks in advance for any clarification I get.
KO
KO Abear is offline
post #2 of 4 Old 05-20-2002, 08:25 PM
JeffDM's Avatar
The DVD player settings do not need to change, the player will just output the signal as it sits on the disc.
For non-anamorphic, letterboxed discs, the projector display setting will probably need to be set to "normal", just like you would with a DVD with a "standard" aspect ratio DVD, such as M*A*S*H or most other TV shows.
I can't help you on the double letterbox bars, adjusting the brightness setting might help them blend together, but I can't say for sure as it might crush blacks in the image too.
JeffDM is offline
post #3 of 4 Old 05-21-2002, 11:49 AM
Huey's Avatar
Some nonanamorphic movies are recorded with the "black" (really more dark gray) letterbox bars built-in. Thus, you'll get these bars which will appear less dark than LT150's own letterbox bars because in the latter case it's unused pixels with the mirrors turned off completely while in the former the pixels are turned on slightly to reflect the recorded "black" or gray bars.
Huey ;-]
Huey is offline
post #4 of 4 Old 05-21-2002, 05:14 PM - Thread Starter
KO Abear's Avatar
That makes sense...thanks a ton guys.
KO
KO Abear is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
