LG PB60G LED 1280x800 500 LUMENS - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #271 of 280 Old 12-28-2014, 11:47 AM
eazye84's Avatar
i just bought this projector and with proper calibration i have never seen a better image coming from any 1080p projector
3d is amazing no cross talk at all under any circumstance
colors are amzingly vivid and blacks are awesome when setting brightness 35 and under.
very happy with purchase
just curious if anyone has been able to make a inf for 720p 3d or if its even possible.
basically i need help with 3d and getting 720p 3d
eazye84 is offline
post #272 of 280 Old 12-28-2014, 07:14 PM
cohete's Avatar
Just got this projector at christmas, was wondering what people were using for ceiling mounting. The small tripod screw hole is off center and does not seem to properly distribute the weight, I found a camera ceiling mount with the right screw thread but am worried about long term mounting from it. Does it need maybe a bracing arm to distribute the torque from the mounting screw being off center? Or can the casing hold up long term without one.
I second your thoughts easye84, I've never had a projector before and am absolutely amazed at the image quality of this tiny little thing, using a 100" pull down screen here.
cohete is offline
post #273 of 280 Old 01-18-2015, 04:28 PM
Zorba922's Avatar
Quoted: 3351 Post(s)
Liked: 2374
My apologies if this question has been asked before, but I didn't want to plow through all 10 pages of this thread:
What are the differences between this PB60 and the PB63? Is there a significant performance upgrade, or just minor tweaks/features?
Zorba922 is online now
post #274 of 280 Old 02-17-2015, 10:09 AM
Liked: 0
Thanks espetodesardina, due to your input on this thread and great photos I've just ordered this projector. I had been very confused about which pj to buy and this appears to be the best choice for my needs. My question now is what size screen to buy? 106" 16:9 or 120" 16:9? It appears that the pj can handle a little more than 106" in a darkened room. Is this correct? Is 106" the maximum size? Are there any issues by projecting 106" image on a 120" screen? Sorry for newbie questions but I really don't have a clue, this will be my first projector setup.
antsinmypants is offline
post #275 of 280 Old 06-09-2015, 03:50 AM
Liked: 0
Is anybody else seeing rainbows with this projector? I am seeing a lot of rainbows in dark scenes, and just wondered if anyone else faces the same issue....
orc_killer is offline
post #276 of 280 Old 08-19-2015, 11:17 PM
Liked: 0
Hi to all. I'm new buyer to LG PB60 and this discussions was very helpfull for my decision.
For now I project to a white paper eheheh, I try from 2,5 and 3,3 mt. I try with tripod and also a gorilla pod for fast installation that it my use.
I have tried expert 1 set up of "especosardina" but for me it's better film set up or sport set up with little adjustement. For now. I try with large file mkv very good quality (BD). In this moment at 3 mt I see a good film with about 80' . For me 100' or higher are out of LG's power.
With sky sat hd signal is little bad...and with no hd films need to reduce distnce projecton (I think in this option it's good the short dimension of LG).
For now I stop.
I'm waiting a basic Pj to 100' with stand for fast installation.
Sorry for my bad english.
tuzzo is offline
post #277 of 280 Old 08-24-2015, 12:50 AM
Liked: 0
A question: the keystone correction is a bad choice for the quality? It's better make it off?
tuzzo is offline
post #278 of 280 Old 08-24-2015, 03:38 AM
t-n-o's Avatar
Quoted: 69 Post(s)
Liked: 32
Yes, it's better to work without it.
t-n-o is offline
post #279 of 280 Old 08-26-2015, 04:49 AM
Liked: 0
Here i am after PJ 100" basic. My distance of view is 3,2 mt. For me is too near for big dimension. I've try BD "Il Gladiatore" and I think the bigger screen size diagonal is 80", but it's better stay down... 60/70 " is better for me. I put it at 2 mt about me. I would know your set up image. Now have modify standard image. In general the colour is too strong expecially the red. I make off any filter.
tuzzo is offline
post #280 of 280 Old 07-19-2016, 12:55 AM
Liked: 0
Im wanting to mount he unit on the ceiling (so its upside down as some others in the forum have done) BUT the options to flip the image (in the PJT menu) are greyed out on the menu! I can't for the life of me work out how to flip the image... can you tell me how to do it?
Cheers!
porwl is offline
Dell M110 Ultra Mobile Projector , Epson , Projectors
