LG PB60G LED 1280x800 500 LUMENS - Page 9 - AVS Forum
post #241 of 266 Old 01-23-2014, 06:57 AM
Luke Chara's Avatar
Originally Posted by takeuptime View Post
I don't know about the K135, but the PB60g has a native aspect ratio of 16:10. When you watch movies at either 16:9 or letterbox, there will be a faint black boarder around the image as the projector is still and is always outputting the full 16:10, but is scaling the "image" to its correct size unless you change the projector settings to stretch the image to fill the screen.
I don't mean the 16:9 black bars I mean a faint border all the way around the image.
It's as though its scaled down or something.
Luke Chara is offline
post #242 of 266 Old 01-25-2014, 02:44 AM
Luke Chara's Avatar
Also this projector does not display a maximum resolution of 1920x1080 it's 1680x1050 but scales it down to 720p Pixels which makes the image look square not proper 16:9
post #243 of 266 Old 01-26-2014, 11:14 AM
Valone's Avatar
Realy the native resolution of the projector would be greater than 720p? how can use the projector in native risolution?
Valone is offline
post #244 of 266 Old 01-26-2014, 12:25 PM
Luke Chara's Avatar
You cant use it in the native resolution, it just takes the 1080 image and resizes it to 720
post #245 of 266 Old 01-26-2014, 12:32 PM
Valone's Avatar
Sin, use native resolution with a PC might be interesting...
Valone is offline
post #246 of 266 Old 01-26-2014, 11:57 PM
Luke Chara's Avatar
Anyone compared this projector the the Acer K135/2 would be interested in knowing which one is better, thanks.
post #247 of 266 Old 01-27-2014, 05:20 AM
isvana's Avatar
Pretty sure the native resolution is WXGA not 1680x1050. If it was higher than WXGA then LG would be foolish in not advertising it as such. I could believe the resolution of the internal LED panel is higher than WXGA but is restricted to a subset by the hardware but have not seen any evidence for that.
PS I consider "native resolution" as the resolution that is (a) maximum allowed input that (b) is not interpolated from the imager.
PPS: would be nice if you could get higher resolution from this monitor - lower priced LED 1080 monitors can't be too far away though...
isvana is offline
post #248 of 266 Old 01-27-2014, 11:17 AM
Native resolution of projector is 1280x800 16:10
720p resolution is 1280x720 16:9
There are no issue with the projector scaling the image. Choose option "Just Scan" and any HDTV 16:9 content will display with the proper aspect and resolution.
You can hook the projector up to a computer and display a 1280x800 image if you set your monitor resolution accordingly.
isvana likes this.
takeuptime is offline
post #249 of 266 Old 01-27-2014, 12:26 PM
Valone's Avatar
Valone is offline
post #250 of 266 Old 01-27-2014, 12:32 PM
Valone's Avatar
I'm using it with my laptop, hp envy 17 (intel i7, 6gb ram, ati radeon hd 5850),
if I use 1280x800(recommended) creates two black frames around the image, one large and one small
if I use the 1680x1050 image becomes bigger and gets to cover the largest black frame and icons on desctop become more small, while the frame remains small
what do you think?
I took 3 photos to show you but tells me that I do not have permission to publish
ozdemir likes this.
Valone is offline
post #251 of 266 Old 01-27-2014, 12:45 PM
Valone's Avatar
Valone is offline
post #252 of 266 Old 01-27-2014, 12:48 PM
Valone's Avatar
Where should I ask to be able to post 3 photos taken by me?
Valone is offline
post #253 of 266 Old 01-27-2014, 12:48 PM
I only tried the projector with my computer when Ii first bought it a year ago, but i don't remember having too many issues using hdmi. You could also try 1920x1080 and see if that works. With all of these resolutions, make sure to play around with the aspect ratio settings. I think "Just Scan" is the setting you want.
post #254 of 266 Old 01-27-2014, 02:22 PM
Valone's Avatar
I just noticed that using the laptop Just Scan is disabled.
how can is possible?
Valone is offline
post #255 of 266 Old 01-28-2014, 04:32 AM
Luke Chara's Avatar
The reason you get that border around the image is probably because the PB60G's maximum resolution is 1680x1050 not 1920x1080 and scales it to 720p
post #256 of 266 Old 01-30-2014, 02:39 PM
isvana's Avatar
Maximum *input* resolution? Yes it will scale higher input resolutions down, but for best clarity you should set the native WXGA resolution of course.
isvana is offline
post #257 of 266 Old 02-05-2014, 02:33 PM
espetodesardina's Avatar
Location: Málaga,Andalucía Enjoying Spanish Costa del Sol
Liked: 43
espetodesardina is offline
post #258 of 266 Old 02-20-2014, 04:16 AM
ozdemir's Avatar
hi. I am currently taking a narrow view on the screen. how can i get 1920x1080 resolution in full screen with my computer?
ozdemir is offline
post #259 of 266 Old 04-01-2014, 09:30 AM
smele's Avatar
Hi all
Has anyone figure it out why on some models of pb60g there is limited access of options in expert mode? I connected mine with hdmi cable but there are still 2/3 of options unavailable so i can't get best picture form it :confused:
smele is offline
post #260 of 266 Old 04-03-2014, 12:24 AM
marvmikey's Avatar
I was on the fence about this projector but those shots of RUSH looks brilliant, I'm buying cheers
marvmikey is offline
post #261 of 266 Old 04-11-2014, 07:53 AM
Imtiaz Hussain's Avatar
excellent review good work. can you describe something about its 3d readyness have you ever watched a 3d content on PB60
Imtiaz Hussain is offline
post #262 of 266 Old 04-17-2014, 07:35 AM
jura1986's Avatar
I figured out how to change the settings in expert mode, change the resolution to 1280x720 and will be able to change the color, and the rest
jura1986 is offline
post #263 of 266 Old 04-17-2014, 08:31 AM
Ftoast's Avatar
Quoted: 82 Post(s)
Liked: 69
It's the same with other LG models, you only get FULL expert settings (HDMI from PC) at 720, 1080, and maybe one other resolution setting..strangely not at 12X8, but then again when you use hdmi the PJ is expecting either 1080 or 720, not a PC.
This is also why using 12x8 causes a thick boarder when you're using HDMI. This shouldn't happen through VGA.
Simple <$250 dedicated black-fabric theater room, build in a day, takedown in an hour.
Ftoast is online now
post #264 of 266 Old 04-25-2014, 06:51 AM
Carrowkeale's Avatar
I've recently purchased the LG PB60G and I think it's a great projector. I'm currently projecting onto my white ceiling while watching in bed and the image quality is very good. I'm using your settings in expert mode :). Could you advise which screen you are using and where did you purchase it?
Carrowkeale is offline
post #265 of 266 Old 07-01-2014, 02:35 AM
lucaiuli's Avatar
my 3D experience with the LG PB60G 3D ready projector:
- using my Dual Atom HTPC from AsRock I couldn't make it work because of the sluggish CPU that couldn't handle 3D Side-by-Side videos
- using late 2013 mac mini with Intel I5 CPU and AMD video card - windows 7 (bootcamp) - Stereoscopic Player - K-Lite Codec Pack (for mkv video formats and 3D subtitles display) I was able to watch 3D movies and the outcome was very acceptable. Also as I said before I used this 3D Active glasses.
The 3D effect is very good when watching cartoons movies, but on the real action movies it's not very good on fast scenes.
Anyway, now I'm looking for another option for a stable mini HTPC that could handle 3D, the mac mini it's not mine
So, is there anyone that use Intel NUCs or other new Haswell systems, or new Celeron that could make a test with Stereoscopic Player (free trial) in Software Page Flipping video mode and a Side-by-Side 3D video test file?
I would like to know how this systems handle 3D video formats. You don't need a 3D TV, monitor or projector to see if the system can handle.
Thank you.
Iulian
lucaiuli is offline
post #266 of 266 Old 07-25-2014, 07:54 AM
Liked: 43
Squeezing the PB60G to the maximum
MotoGP 2014 Mugello Highlights Slow Motion
Gru 2
The pics are made with ambient light in the room
Walking with Dinosaurs
Futbolin
God bless the economic Home Theater
Dell M110 Ultra Mobile Projector , Epson , Projectors
