hi, i know this is a cheaper projector but i was happy with it... while it was working of course.
the other day i turned it on and it said searching for signal but would never connect. i've tried different connectis but i get the same thing. then about an hour later i tried it again and it worked. then the next day it stopped working again.
i havent even used this long enough to need to replace a bulb :/
i'm thinking it needs a main board but i called optoma to get some advice and they said it may be a main board also. i was wondering if anyone had any experience with this projector. any advice? if it does need a board, where can i get one?
thank you.
thank you.
