Panny AE900 died - replace with Epson 3010? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-07-2012, 02:22 PM - Thread Starter
Tyson's Avatar
I am a longtime member here, but not active since a few years ago when I bought a Panny 900 based on the info I found here. My Panny died due to a chip malfunction, so I'm looking to get a new projector. I do have a few constraints that make this a bit more tricky than when I got the Panny initially.
$2k budget, max
3D preferred
Rainbow senstive, so no DLP
Family room, not dedicated HT
Grey Screen .8 gain (cannot be changed)
Pre-existing shelf for mount - dead center vertically, 1 foot offset horizontally.
It looks like the 3010 meets most of my requirements, but it has no lens shift. But, can't I still get it to work using keystone correction? I am willing to give up a bit of sharpness in order to get the 3D and the brightness. But if there's another projector that I'm not aware of, I'm all ears!
Also, I will have the $$ to do this at the end of August, and I know there's a big show in September, should I wait till then to see what comes out? Or do you think the 3010 won't have much new competition in the foreseeable future?
"Words are a lense to focus ones mind"
Tyson is offline
post #2 of 2 Old 08-17-2012, 07:47 PM
fbunn's Avatar
$2k budget, max
3D preferred
I just replaced my AE900U with an LG PA70G.
The light output of the LG was superior, and best yet, NO MORE BULBS!
I'm sure there are better projectors for unUder $2K, but I'm perfectly satisfied with my new LG.
fbunn is offline
