Anamorphic on Infocus LP350? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-20-2002, 11:33 PM - Thread Starter
miol11's Avatar
Is it possible to show real 16:9 anamorphic picture on the Infocus LP350?
Does it have some "16:9 mode"
//Micke O
miol11 is offline
post #2 of 3 Old 05-21-2002, 06:27 AM
toxic candy's Avatar
Yes it does....
If your DVD player is set to output 16:9 anamorphic, you will be able to choose a Standard mode on the LP350 (people will be stretched up - full 4:3 display) so you can use a lens to put everything is place like the panamorph, or you can use the WIDESCREEN mode and the LP350 will put everything in place for you in the middle of the screen (full width).
Hope it helps,
Pierre
toxic candy is offline
post #3 of 3 Old 05-22-2002, 12:12 AM - Thread Starter
miol11's Avatar
Pierre: Thank you!!
miol11 is offline
Closed Thread Digital Projectors - Under $3,000 USD MSRP
