Will non-magnetically shielded speakers damage a projector if placed close? - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2012, 02:29 PM - Thread Starter
BestInTheWorld's Avatar
I want to get some speakers, BUT I just learned they are not magnetically shielded and I know they can damage TVs and possibly laptops.
Room size will mean I have to place the speakers about 2 feet away from either side of my Epson 8350 projector (3 LCD lens)
I never owned non-shielded speakers, so will this damage the lens?
BestInTheWorld is offline
Old 07-11-2012, 04:22 PM
Sheridan1952's Avatar
That used to be true of tube-type tv's, the crts. Not true with digital equipment. So the projector is fine and so is the laptop..
Sheridan1952 is offline
Old 07-11-2012, 07:48 PM - Thread Starter
So this should extend to receivers, phones and BD players true?
Whew,what a relief if that's the case!
Old 07-11-2012, 09:24 PM
Correct. With the exception of the headphones, there is nothing in any of those that magnetism would affect. Headphones operate with a magnetic coil, but but unless you have your head next to the speakers when using the headphones, you won't see any effect. Even then, it's iffy.
