Issues with wireless HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-21-2012, 10:32 AM - Thread Starter
mcd4959's Avatar
Hi guys -
Just got the 5010e a couple of weeks ago and so far I am really loving it. I am having one weird issue that I hope you can offer some advice on.
The wireless HD signal is great - no issues whatsoever once it is up and running. The problem is startup - I always get the "Wireless HD connection failed" message when powering up - but if I manually turn off and on the wireless unit the connection is pretty much immediate, and then works fine for the duration of whatever I'm watching, including switching sources from Blu-ray to DirecTV. The unit is located only about 12 feet away from the projector, at a very slight angle.
I use a universal remote (Pronto) macro to turn on things in this sequence: projector, receiver, Blu-ray. Screen is electric and on a 12v wireless trigger.
Equipment is Denon AVR-4311 and Denon DBP2012UD Blu-ray. DirecTV HD DVR.
Any brilliant ideas?
Mark
I love this site!
mcd4959 is offline
post #2 of 3 Old 07-21-2012, 10:37 AM - Thread Starter
mcd4959's Avatar
Sorry meant to post this on Epson froum. Have asked mods to delete. Will repost in the right spot.
I love this site!
mcd4959 is offline
post #3 of 3 Old 09-13-2012, 01:06 PM
tvandijl's Avatar
Did you solve this problem? I have the same problem with a 9000W, can't find your new thread.
tvandijl is offline
