Holy crap at the bulb time counter!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-25-2012, 09:29 PM - Thread Starter
jsw5620's Avatar
Just got my AR100U in and got it mounted. I have had it turned on for 30 minutes at the most and the counter is already reading 2 hours. What is up with that?! It was a brand new projector. This thing is counting fast!
jsw5620 is offline
post #2 of 8 Old 07-26-2012, 07:32 AM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Congratulation for your new pj! Do you mind sharing some nice screenshots? biggrin.gif
WereWolf84 is offline
post #3 of 8 Old 07-26-2012, 07:36 AM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Where did you get it?
Sounds like you may have got a B stock unit.
2016
42Plasmaman is offline
post #4 of 8 Old 07-26-2012, 08:14 AM
sog35's Avatar
Liked: 27
each bulb strike counts as 2 hours
sog35 is offline
post #5 of 8 Old 07-26-2012, 01:16 PM - Thread Starter
jsw5620's Avatar
I got it from Projector People. Sog, are you saying every time I turn it on it adds 2hrs?
jsw5620 is offline
post #6 of 8 Old 07-26-2012, 02:35 PM
Mr.G's Avatar
Quoted: 605 Post(s)
Liked: 311
Here's a quick and dirty explanation.
Personally, this is my take on the whole lamp thing. When a manufacturer says that their lamp is rated for 4,000 hours, what that really means in my mind, is that it's rated for 1,600 strikes. They probably figure that when somebody uses the projector, they use it for about 2 to 3 hours per time. So, if you use the projector for 2 or 3 hours per session, then your bulb will have about 1600 strikes in it (if it's rated at 4,000 hours, and obviously, this is if everything works out perfectly with the bulb).
Now, it's my opinion, that you should basically almost just forget about the hours, and think about the strikes. The bulb only has so many strikes in it's lifespan. So, when I'm using the projector, I plan on using the thing for a good 4 or 5 hour stretch of time, if not more. Using it for only 1 or 2 hours, is kinda a waste of a strike imo. So, lets say on a rainy Sunday afternoon I'm watching football for like 6 hours, but I need to leave the house for a few hours, I'll just leave the damn thing running while I'm gone. No use in turning it off for a couple of hours, and then turning it back on to watch the nite game. I just leave it running, and when I get back home, I just go into the room and watch the nite game. When I know that I'm not going to use the projector for at least 5 hours, then I'll shut it off. Basically, I pretty much never strike the bulb twice in one day. If I'm going to use my projector that day, then I'm going to only use it once, and try to maximize my time with it.
Also, regarding the bulb strike thing... Let's say my bulb has 1,000 strikes in it. I know that if each time I turn it on, I leave it running for a full 24 hour period, that my bulb would theoretically have a lifetime of 24,000 hours. Obviously that is totally ridiculous, and I'm aware of this. So, I know there is a limit to how many hours you can run the bulb off each strike, but I seriously feel like if I use my projector for 8 hours off each strike, it's the equivalent of using a projector twice, for only 2 hours, and shutting it off after the two hours is over. In that scenario, you are only using the projector for 4 hours, but I think the one strike, 8 hour scenario is actually less wear and tear on the bulb.
http://www.avsforum.com/t/1241000/leaving-the-projector-on-to-get-a-cold-one-or-two#post_18459279
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #7 of 8 Old 07-26-2012, 03:48 PM - Thread Starter
jsw5620's Avatar
Thanks for posting that G! I was just shocked when I looked at it. Proj People stated I could return it with no restock fee within 30 days with less than 4 hours on the bulb. I am waiting to get my screen in before I decide if its going to be bright enough. Looks good so far and more than likely going to keep it instead of swapping it for the optoma. It has less than 30 mins on it and for it to jump to 2 hours is crazy to me. I guess I won't turn it on again until I get the screen and get it put up.
jsw5620 is offline
post #8 of 8 Old 07-27-2012, 09:47 AM
sog35's Avatar
Liked: 27
i was joking, sorry.
sog35 is offline
