Hi,
Usage at 421 hours at Low lamp mode. No keystone adjustment is used on the projector. NO optical filter on the AE100. Below is my current config in the past 150 hours or so and may stay that way to the end of...
Room setup: size around 8'x9'. Side walls are mostly covered so there is only average light reflection in the room.
Screen: wall mount Vutec BriteWhite 1.5 gain 50"x67" 4:3.
Viewing position: around 110" to screen so it's about 1.6x screen width away.
AE100 position: ceiling mounted around 113" from lens to screen. Min zoom (smallest image) for 16x9 anamorphic and max zoom (biggest image) for 4:3/letterbox source.
Warning: this config is for my own setup and my taste only. The values are NOT some universal magic setting for any AE100. That being say, if one has the exact setup, I do expect one to see a similar picture which looks GREAT!
DVD source:
Panasonic RA71 -> S-video (2m StraightWire Silver S-video cable) -> iScan Plus V1 -> 15pin RGB (Canare stock 75ohm 5m 15pin-to-male-BNCs + Canare stock 75ohm 2m female-BNCs-to-15pin cable) -> AE100 15pin VGA input.
Panasonic RA71 config:
All viewing is in the following picture control mode:
U1: Contrast 0 (default), Brightness +5 (default 0, range from 0 to +15), Sharpness 0 (default), Color -5 (default 0, range from -7 to +7), Gamma +5 (default 0, range from 0 to +5).
U2: all default.
AE100 setting values (16x9 anamorphic DVD):
Picture:
Picture Mode: Normal
Bright: -18
Contrast: +15
Sharpness: 0
Color Temp: Warm
W-BAL R: +8
W-BAL G: -6
W-BAL B: +16
Signal Mode: WIDE480
Position:
H-Posi: -8
V-Posi: +19
Dot CLK: -4
CLK PHASE: 0
Option:
PC Priority: WIDE
For 4:3/Letterbox, all values as above except:
Position:
H-Posi: +16
V-Posi: 0
Dot CLK: -8
Option:
PC Priority: Normal
Picture:
Signal Mode: VGA480
HDTV (1080i) source:
JVC DH35000 DVHS (Japanese model) -> 1080i component -> KeyDigital KD-CTCA2 component to RGB transcoder (auto sense mode) -> 15pin RGB (Canare stock 75ohm 5m 15pin-to-male-BNCs + Canare stock 75ohm 2m female-BNCs-to-15pin cable) -> AE100 15pin VGA input.
AE100 setting values:
Picture:
Picture Mode: Cinema
Bright: +12
Contrast: +12
Sharpness: 0
Color Temp: Normal
W-BAL R: -32 (min.)
W-BAL G: +2
W-BAL B: +18
Signal Mode: HDTV60
Position:
H-Posi: +9
V-Posi: 0
Hope it helps.
regards,
Li On
Added: Jun 4, 02.
U1: Color -2 (default 0, range from -7 to +7)
Picture:
Bright: -8
HDTV 1080i AE100 setting values:
Picture:
Bright: +18
W-BAL R: -22
W-BAL G: 0
END.
DVD source:
U2: all default.
Picture:
Bright: -18
Contrast: +15
Sharpness: 0
Color Temp: Warm
W-BAL R: +8
W-BAL G: -6
W-BAL B: +16
Position:
H-Posi: -8
V-Posi: +19
Dot CLK: -4
CLK PHASE: 0
Option:
PC Priority: WIDE
Position:
H-Posi: +16
V-Posi: 0
Dot CLK: -8
Option:
PC Priority: Normal
Picture:
Signal Mode: VGA480
Picture:
Bright: +12
Contrast: +12
Sharpness: 0
Color Temp: Normal
W-BAL R: -32 (min.)
W-BAL G: +2
W-BAL B: +18
Signal Mode: HDTV60
Position:
H-Posi: +9
V-Posi: 0
Hope it helps.
regards,
Li On
Added: Jun 4, 02.
Picture:
Bright: -8
Picture:
Bright: +18
W-BAL R: -22
W-BAL G: 0
END.
