Panasonic PT-AR100U Eco Mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-04-2012, 11:25 PM - Thread Starter
ryanb650's Avatar
I just got this projector set up and so far i love it with the exception of one problem. I would like to extend the bulb life, but when I select Eco under Lamp Power there is no change in brightness at all no matter what the source or ambient light is. I cant see to find any information regarding this and I am curious if I have a defective projector. There is however a change in the fan speed when changing between the two modes just not to the output. Any help would be appreciated.
ryanb650 is offline
post #2 of 3 Old 08-05-2012, 08:18 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Have you double-checked the settings on page 67?
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #3 of 3 Old 08-05-2012, 11:45 AM - Thread Starter
ryanb650's Avatar
That was it! Thanks for catching that. I had the Eco Management set to Auto. Once I turned that off the lamp changes brightness as expected. Now its time to get back to enjoying my first projection set up! Thanks again for the help. You saved me a ton of worrying.
ryanb650 is offline
