Panasonic PT-AE3000 unable to focus image on whole screen - AVS Forum | Home Theater Discussions And Reviews
Old 08-05-2012, 06:37 AM - Thread Starter
MatGO's Avatar
Hello, I have an issue with focusing the Panasonic PT-AE3000. Im not able to focus the image over all screen. For example If I focus image at the right corner image at the left side is blurry. If I focus it at the center image is blurry at the sides. The screen is straight and the projector is not angled. It looks like some issue with lens. I would to fix this. If Im watching movies it doesnt matter so much but If Im working with notebook Im not able to read the whole screen..
Any suggestions please?
MatGO is offline
Old 08-05-2012, 01:12 PM
Boiler Jim's Avatar
You most likely do not have the front of the projector parallel with the screen. It should be. Once it is parallel with the screen, you can use the lens shift of get the image centered on the screen, then you should be able to focus the whole image on the screen.
Jim
Boiler Jim is offline
Old 08-05-2012, 02:57 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Also using lens shift can degrade focus, the more lens shift in use the more the focus can be degraded.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
