Help! Benq W6000 mounting query - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-05-2012, 06:44 AM - Thread Starter
karl75's Avatar
Hi all,
Do i need an extended/adjustable ceiling mount for BenQ w6000 to clear the light fixture placed halfway between the PJ and the screen?
The light fixture is about 16 inches in height, from ceiling to edge. We have a 5.5 meter x 3.5 room. Do i need a 16 inches ceiling mount? Or can i just use the PJ's vertical shift lens?
Any suggestion will be appreciated.
karl75 is offline
post #2 of 2 Old 08-05-2012, 12:06 PM
Boiler Jim's Avatar
Well... Light travels in straight lines. Get an outline of the screen on the wall -- or mount the screen. Put your head where the lens of the projector would be and see if the fixture blocks any part of the screen. If it does, you'll have to lower the projector or move the screen or change the fixture.
Jim
Boiler Jim is offline
