HC6000 Replacement Bulb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-06-2012, 04:11 AM - Thread Starter
networkn's Avatar
Hi There!
My local supplier just quoted me $520+Tax for the new bulb on my projector. I have seen on ebay they range in price from about $170 > $320.
A lot of them refer to OEM Bulbs and "compatible" housing.
Are these safe to buy? Will they affect my picture quality? Does anyone know of a reputable source who ships internationally that isn't too expensive?
Should I replace just the bulb or bulb plus housing?
How can I tell which of the OEM brands my bulb is and will it matter if I get an Osram if my current bulb was a Philips?
Thanks in advance.
networkn is offline
post #2 of 2 Old 08-09-2012, 07:44 AM
Mr.G's Avatar
Quoted: 609 Post(s)
Liked: 319
Unless you're willing to roll the dice with a clone bulb it's always best to go with an OEM bulb. Provantage has an excellent reputation and ships internationally.
http://www.provantage.com/mitsubishi-vlt-hc5000lp~7MITP069.htm
http://www.provantage.com/international-orders~xintl.htm
If you still have questions you can email or call.
http://www.provantage.com/contact-information~xcontact.htm
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
