What's a good upgrade for the Infocus 4805? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-12-2012, 10:26 AM - Thread Starter
hulka's Avatar
I'm looking to replace my SP4805 and I need a little guidance. I haven't looked at any projectors since I bought it and I'm sure the technology has made some advancements since then. I have been really pleased with the Infocus and would like to stay with them, but from what I can see, that doesn't look possible. Here's a description of my current setup.
It's used in a dedicated home theater in my basement. Total light control (no windows). I project from the ceiling-mounted SP4805 onto a 100" (approx) Da-lite screen from about 12 - 15 feet away. The sole video source is a Popcorn Hour C-200 Networked Media Server connected using an HDMI cable with a DVI adapter at the projector end.
Since the C-200 supports 1080p, I would like a projector that can display that resolution. I run the PCH at 1080i.
3D is not needed.
I'd like to keep the price below 3K, but 2K would be much more likely to get past my CFO (my wife ;-).
Any and all help is greatly appreciated. I selected the InFocus based on things I read and learned here and I couldn't be happier with that decision. I am hoping you guys can help me pick its replacement.
Hulka
You get in the cage......cage goes in the water......shark's in the water.
Farewell and adieu to you fair Spanish ladies.....
Hulka
hulka is offline
post #2 of 7 Old 08-12-2012, 05:01 PM
coderguy's Avatar
Quoted: 504 Post(s)
Liked: 345
The B-Stock JVC RS-40 or RS-45 from AVS if they still have any left.
Access HERE from this thread
coderguy is offline
post #3 of 7 Old 08-12-2012, 05:34 PM - Thread Starter
hulka's Avatar
Looks like I missed the boat on that. I appreciate the help, though. Thanks!
Hulka
hulka is offline
post #4 of 7 Old 08-12-2012, 07:33 PM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #5 of 7 Old 08-13-2012, 09:33 AM - Thread Starter
hulka's Avatar
Thanks! I will look into this model asap.
Thanks again for the suggestion!
Hulka
Hulka
hulka is offline
post #6 of 7 Old 08-13-2012, 02:18 PM
TechFan84's Avatar
Maybe the Epson Home Cinema 3010e, it's just below $2000 and can be found for even cheaper if searched for. Here's a review:
http://www.pcmag.com/article2/0,2817,2400955,00.asp
TechFan84 is offline
post #7 of 7 Old 08-13-2012, 03:52 PM - Thread Starter
hulka's Avatar
Hmmnnnnnn.......I hadn't imagined straying from DLP. I've been really, Really pleased with the performance of the 4805's DLP engine. No rainbow effect and no screen door effects either.
I forgot what choosing a projector the first time was like......thankfully ;-)
Hulka
hulka is offline
Infocus , Ceiling Mount Universal Epson , Da Lite Screens , Raysonic High Definition Vacuum Tube Preamplifier C200
