Fan replacement in Benq W6000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-12-2012, 11:38 AM - Thread Starter
mears's Avatar
The W6000 is pretty loud and unfortunately is pretty close to the ideal seating position in my home theater. I'm wondering if anyone has swapped out the fan in this guy or know the make/model of the factory installed fan. I figure I can probably find a high quality DC fan that puts out the same CFM at a lower noise level.
mears is offline
post #2 of 2 Old 08-19-2012, 12:18 AM
Michael2000's Avatar
Liked: 27
That would be a tricky replacement, because you would need to match the CFM, and pressure ratio. It would probably be better to build a sound enclosure with a oversized fan.
Michael
Michael2000 is offline
Benq , Projectors , Benq W6000 1080p Dlp Projector
