Screen recommendations for the 8350 - AVS Forum | Home Theater Discussions And Reviews
Old 08-16-2012, 08:57 AM - Thread Starter
tsrjaa's Avatar
Hi All, just ordered my 8350 should be here this week. Was going to put it in my family room for multi use, movies and sports. I'm thinking of going with either a 92 or 100 inch screen. Projector will be about 10 feet away. Would a 92 inch with modest gain 1.1 for instance be too bright in a family room with modest ambient light? I do have blackout curtains in the family room which cuts down on the light some, however walls and ceiling are all white. Distance is relatively close as well, worried about hot spots. Any input is welcome, thanks.
tsrjaa is offline
