Need help speccing a replacement projector - 4500+ lumens, short throw - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-18-2012, 05:31 PM - Thread Starter
George Reynolds's Avatar
Long story short, the projector at our church is dieing a slow death. It's about 10 years old and has issues. In any case, the plan is to replace it. This is the model currently in use - http://www.aboutprojectors.com/Panasonic-PT-L6510U-projector.html. The current set up is a screen that's about 12' x 9' or so with the projector set in an attic space behind the screen in a rear projection setup.
I went out and grabbed this guy off Amazon - http://www.amazon.com/Optoma-TX779P-3D-Lumens-Multimedia-Projector/dp/B005C982P4/ref=sr_1_2?ie=UTF8&qid=1345336099&sr=8-2&keywords=5000+lumens
It didn't work out well for me. Turns out the old projector is about 10' or so behind the screen so a short throw is what I'm going to need. In short my question is whether the Optoma TX779P will work with some kind of short throw lens or if I need to look at another model of projector? If that's the case, what would the experts recommend for rear projection ~10' throw range and as 12' x 9' setup?
George Reynolds is offline
post #2 of 4 Old 08-19-2012, 01:34 AM
rekbones's Avatar
Quoted: 478 Post(s)
Liked: 246
Have you considered a mirror for more throw distance. For rear projection and flexable space behind the screen mirrors work out well
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #3 of 4 Old 08-19-2012, 06:11 AM - Thread Starter
I've not heard of this. I'm not particularly knowledgeable on projectors. Can you link me to something with more information on a setup like this?
post #4 of 4 Old 08-19-2012, 11:09 AM - Thread Starter
After looking more at the current projector, it would appear that it has a short throw lens installed on it already. Would it be possible to simply move this lens to the new projector? What would that involve? Would it fit or would there be issues making it work? Would I be better off buying a new short throw lens?
